This will be my second build in the Ncase M1 (current PC in my sig below), this time using the v6.1.
Spent a couple months gathering parts and reading extensively on similar builds and difficulties and problems that might arise and finally gathered all the parts for it. The most difficult was to source an Apogee Drive II. I decided early on to use this in the build with the possibility of adding a GPU block later for a complete water cooling. For the time being will leave the GPU on air though. Also will add an ODD when it arrives, already have the odd top panel.
Started the build slowly today and will take a couple of days I guess to complete.
Parts:
CPU: AMD 3950X
Motherboard: ASUS Crosshair VIII Impact
RAM: G.Skill Trident Z DC 3200MHz 2x32GB CL14
GPU: ASUS Strix 2080Ti OC
PSU: Corsair SF750
Nvme: Corsair MP600 2TB x 2
SSD: Samsung 860 EVO 4TB x 2
Fans: Noctua NF-A12x15 chromax x 2 (bottom case), Noctua NF-A9x14 HS-PWM chromax (rear exhaust)
ODD: UJ267
Watercooling parts:
Radiator: Alphacool ST30 v2
CPU lock+pump: Swiftech Apogee Drive II
Fittings: Alphacool TPV metal (straight + 90°, temp sensor fitting, ball valve, Coolance QD3 quick disconnects)
Tubing: Alphacool TPV
Fans: Noctua NF-F12 PWM chromax black x 2
Other:
J-Hack M2427 mod/cables
Fujipoly Extreme thermal pads (replaced all the stock pads on the motherboard)
Mini WiFi antenna x 2 (from Taoglas)
I/O rubber covers for unused ports
Black plugs for the Apogee PWM and Molex (my OCD...)
Molex to Sata power adaptor
Slim sata&power adapter for the ODD
180° adapters for the GPU‘s PCIe
Silverstone slim SATA data cables
Don’t have any pics yet, but probably will upload some tonight along with a progress update. So far I’ve installed the motherboard and psu only and will need to measure and check before I cut the tubing.
update pending.
Parts:
CPU: AMD 3950X
PSU: Corsair SF750
ODD: UJ267
Watercooling parts:
Other:
update pending.
