Ncase M1 "tophat" mod & build
jtmsrl
31
wow Im thinking on this. Do you have a temp comparison between with and without hat? maybe using some 2x120mm fan on top as intake and 2x120mm as bottom exhaust? or the other way around.
BTW, is this my viewer or there’s something weird with the file?
Maniac
85
57
Sorry got no comparison with and without tophat.
Yeah that viewer seems to be way off. If you added models one by one, you need to arrange them. But I would recommend to print the clips separately since they should be 100% infill.
Reactions: jtmsrl
jtmsrl
31
Yeah maybe this viewer sucks, back home i’ll try something better. So recommended material would be PETG?
I was thinking on black colored small tophat with 2x120mm slim noctuas to have some extra intake. So far I bought an accelero extreme iii with 2x120mm noctuas running as exhaust and need to compensate some airflow. CPU will be running as exhaust with side fan as intake for some fresh air.
Maniac
85
57
I would recommend PETG if you are printing translucent or transparent filament. But if you are going black, they any would be fine.
jtmsrl
31
and my last question is: why fan railing brackets and underside clips are printed separately and then attached into the main structure? isn’t that the whole point of 3d printing? beeing able to create complex structures as one piece?
Also, will there be any problem by reducing thickness?
Nord1ing
82
38
Did you manage to try that top hat? I’m also considering that option but i don’t really know if it’s worth it given the mesh panels in the case
I tested today the temperatures with and without top hat. With NH-U9S and vented side panel there is almost no difference between two configurations. With glass side panel and top-down cpu cooler maybe there will be more difference.
TheaAmbient temperature 24-25C
PMW Fan settings:
CPU:
GPU:
Side and top-hat:
jtmsrl
31
well that’s marginal and I doubt it even worth it, maybe noise decrease due to fans spinning slower on some test.
Anyways your CPU and GPU temps looks pretty safe without tophat. Did you saw any difference in motherboard and gpu VRM temps? or not monitoring that?
Nord1ing
82
38
I did not monitored VRMs and motherboard and M.2 SDD became around 2 degrees cooler.
BeerNsoup
205
149
Edit: somehow missed a post that was close enough to what I was asking... Sorry to ressurect this for no reason.
