Ok here we go. The models are now published on Thingiverse. Still doing test with the prints. Not easy when you don't own a printer.
https://www.thingiverse.com/thing:3219088
Yeah I was about to do that initially, but since there are currently 3 sizes, it became a mess pretty fast on thingiverse. Files and parts everywhere. I was afraid that people would download or print wrong parts.
It's very easy to cut the model into two STLs, I use "Slic3r" for the job. Then add both parts and rearrange them so they fit on a 200x200x200 bed.
I am currently looking for someone to print the large hat for me at the moment.
I have gotten a few quotes to get this printed via services, but thus far looking at around $250usd to print.
I will be all over this once I find a viable production method![]()
That is just insane pricing. Stay away from that :-)
My local printshop take around 30$ max.
It’s all about settings for the print. I would say the best would be: 10-15% infil, 0.4 layer, with supports. And for the brackets 100% infill.
Yeah, but many people either use CURA or Simplify3D for slicing and they dont have the same tools. And honestly, you should make it as 3 different entries in Thingiverse, and then split the files. This will also get you more hits on Thingiverse and more "likes".
That is brutal. Where are you located?
Yeah, that is more like it. If anyone in europe needs one, let me know and I can give you some info on sending it to you.
Great!Btw: I have also finished my Ncase-build with the tophat, can be found here with plenty of pics:
https://pcpartpicker.com/b/zGD2FT
Aluminium amplifier feet from aliexpress
https://m.aliexpress.com/item/32841...000&pvid=0dee28f8-329e-43f8-894e-5284ac9274bb
