Hello everyone,
Long time since I posted here last, but I've hit a bit of an roadblock and thus need some assistance from the community...
I'm thinking of getting the NCASE M1, but I basically have 3 worries/concerns, that I want to take a deeper look at:
1, Can/will the ASUS ROG STRIX 1080 Ti actually fit inside the M1? I've seen pictures that it does, but haven't seen any picture closer as to how. And in order to fit it, would anything has to go, such as the side panel holder clips for example?...
2, What CPU air coolers actually fit inside the case? As haven't quite figured it out yet. Found on SFFLabs page that a max height of 130mm, but then also found on Hardforum I believe that with the side panel on, that gets shorter? So not sure at all here... Anyone that has any recommendations for what you people have used?
2b, Basically continueing from the point above, do you perhaps know any 240mm AIO's that has a bit shorter and more flexible tubing than for example the Corsair H100 v2 and the ASUS ROG RYUO?
3, What is the main difference (other than the obvious) in going for the window side panel rather than the full aluminium?
It says the following below and just for clarification, does that mean if going with the window side panel, I can't have an 240mm AIO anymore, due to the "side bracket" isn't included?:
Thank you,
Dawelio
Note that all orders of the M1 with a glass side panel do not include the side bracket or 3.5" drive bracket, as these are incompatible.
Thank you,
Dawelio
