MSECORE i3-8100 GTX1050ti 4G Mini PC Desktop
Joedarkness
So on another thread I think I stated I ordered this
https://www.aliexpress.com/store/pr...065.html?spm=2114.12010608.0.0.11512c0d00dDho
It's a very compact PC 8th Gen CPU with a GTX 1050Ti from china what could go wrong ;)
you always have that feeling .. will it be a i3-8100 or will the card be a 650Ti with a flashed bios ?
However it arrived and I must say on the first looks good checked the CPU and it's i3-8100 and 1050Ti is a gigabyte 4Gb card
Installed the ram and SSD and installed windows with no issues load passmark and did the CPU test again all looks great
Do the video card check and aghhh .. the noise !! really noisy coil whine from PC ( passed the GPU test)
Checked the 1050 with another ITX motherboard .. it's fine
Took the board out and used a new 1050 and the noise is there it's not a constant sound it's buzz pitch changes as the test changes
I have reached out to the vendor and will keep you updated
1st Update :- No reply from Vendor sent second email
Instran0
526
107
UPDATE - new revision, improves cooling greatly : https://www.aliexpress.com/item/32890360351.html?spm=a2g0s.9042311.0.0.6f1a4c4d3ue4L3
thewizzard1
344
254
Neat! That's a PIO-format motherboard, ITX size.
Too bad it doesn't have M.2, even with 1 soDIMM slot that'd be all it needs.
thewizzard1
344
254
@Instran0 - PIO format is with the sideways PCI Express slot, on the top of the motherboard (as opposed to the normal slot on the 'bottom' :) Check this thread:
Instran0
526
107
@Instran0 - PIO format is with the sideways PCI Express slot, on the top of the motherboard (as opposed to the normal slot on the 'bottom' Check this thread:
ok - cool.
there is a mSATA port.
Reactions: CARC Mini
