More G-unique BTO PSUs are now available(direct order)
28th Nov 2018,announeced Gunique U0 experience suite price:
400watts set 199USD
500watts set 229USD
price include:
complete psu set(ultimate modded brick,1x 1.8M 10awg dc cable,1x archdaemon limited internal psu,1x MB tray,1x riser card ,1x cpu 8pin cable,1x pcie 8pin cable),1x case/enclousre,shipping to usa(other country+10usd),
upgrade option:
2nd pcie 8pin cable+4.99usd,
8awg dc cable+sleeving in black +9.99usd,
2x2.5 disk bay and 2x12cm sata cable 24.99usd
this month's order will ship in next month
order method:
  1. PM me @guryhwa or send me an email 9842677@qq.com ,or join our discord group telling the hardware configuration and case model,and what kind of basic unit you like to use,the detail cable requirement,what power of adaptor,etc,anything would help me to built to your order.also your shipping address to check the shipping rate for you(mostly via sf-express);
  2. if everything is confirmed,I will send you an invoice via paypal,after you paid it,you order will be arranged asap ,usually it will take about 5-7 days to ship.
all G-unique PSUs are handmake/handcraft of Gury,who is running a one person SMPS workshop.
prices of parts and custom options:
Base unit (12V-in type,no cables)
  • TYPE C,code name Arch Deamon,$49.99,suitable for 120watts-500watts
  • PCB height 27mm
  • Main componets introduce:21 pcs KEMET T520 polymer tantalum Capacitors,2 pcs WE 1090 Inductors ,TI NexFet powerblock,2 toshiba P-mos for 12V loadswitch(4mR Rdson) ,1 infineon mos for 5V load switch;
Arch Deamon can be upgraded ($24.99)to limited edition by add an additional TaCap armor with 28 KEMET T520 polymer tantalum Capacitors,which make total 49 pcs T520 polymer tantalum !
  • to be continued
cables and connectors:
all cables can be customized and soldered to the basic unit,so it is reliable , killed the loss of connector,withstand for large current.
    • Default cables set:
    • [20cm CPU 4+4pin cable,(20awg PTFE silver plated or black silicone wire)] + [30cm+15cm sata*2 cables (20awg PTFE silver plated or black silicone wire)] + [DC input cable with 5.5*2.5 DCjack,30cm 16awg black or white Silicone Wire] +$4.99
    • Custom Cables Length & Connectors (change length,add PCIE 6+2,CPU 8pin,SATA,4pin peripherals)+$4.99 for each set;(t the PCIE cable are soldered to a tiny load-switch behind the dc-jack pcb which is sync. with the basic unit,so count the PCIE cable 's length from dc-jack
    • Custom DC Jack +$9.99 ,Dell dedicated 8pin:
    • Custom DC Jack 7.4*5.0,with 14AWG DC cable:+$14.99:,
    • Custom DC Jack 4pin Din,with 14AWG DC cable:+$14.99
    • Custom DC Jack :GX-16,GX-12 aviation plug,S4 mini DC-jack with 14AWG DC cable ,+$19.99
Power adaptor
  • Power adaptor
    • 300w $59.99 STD version (12V25A,Modded Delta OEM,DELL brick,100-240Vac input,original plastic case and 8pin dc cable :3 pairs of 16awgs +1pair 26awg DC output wire)
    • Ultimate version 400watts $89.99(12V>=34A),450watts $99.99(12V>=38A)Fix and Mod for high temp operation and high reliability,main unit's effiency higher than 80plus platinum,220Vac in,half load )
    • All Ultimate dell brick's dimension is 20cm*9.4cm*3.9cm ALuminun case DC cable of 1 pair of 10awg silicone wire XT90 dcjack(45 amper rated,90 amper peak),500watts brick with 1 pair of 8awg silicone wire,500watts brick is installed dual 3.5cm ultra silent panasonic fans(with temp controlled RPM),other fans mod is an option of 19.99USD
    • secondary spare brick will get a 20% discount.
    • Higher power brick/internal psu can be customized
    • pls prepare a C14 ac cord cable yourself~
    • every dell Brick are modded to increase its efficieny,enhanced its internal heat spreading rate,every modded brick have over-current-protection,short-circuit-protection,over-voltage-protection,over-temp-protection.and they have their own safety certification required by DELL.
warranty:
any basic unit:3 years ,return and repair;anybrick 1 years,return and replace;user pays return shipping
build samples:
1,Arch DEaMon 120watts set with Default cables,Dcjack is 5.5*2.5 type:
2,typc A basic unit 400 watts set,with one 6+2 pin PCI-E connector,4+4pin CPU connector,and 2 sata connectors.input 8 pin(2 M3 screws)DC jack.the PCI-E cable is soldered on the Load switch PCB(On/Off synced. with basic unit) right behind the DC jack,and it ismuch safer than other pcie direct connected to VGA method,for the house-keeping supervisory ship on basic unit will monitor the input voltage,if trigger an OVP,it will shut down the PCIE power:
3,ArchDEaMON limited edition(No1) 400watts set ,Dell dedicated 8pin DC-jack with C14 BRK:
4,VX set for PCfi CAS,5.5*2.5 DCjack ,linear regulator in.so you can compare Gunique PSU with other band's PICO things.by constomized directly soldered cable,Gunique saved lot of precious and limited space on the basic unit,and offer you more and more components like capacitors ,mosfets etc. to increase performance(not by those big,cheap connectors).
and cause it is 12V-in type PSU,it generates little heat that it dont need any heatsink to cover.
5,Arch Deamon limited edition (No2)+ultimate version Modded brick ,dual pci-e 6+2pin VGA cable witn one changable,this set can run i7+1080ti or titan pascal:
to be continued
Craxas
130
147
Just received Gury's ultimate power supply and vx base unit. It has been powering an overclocked 6700k and 1080 FTW. Powers through all my benchmarks without any issues. Can't wait to stick it in my s4 mini!
maybe share some pics? ;)
Instran0
526
107
dimension: 338mm (W) 230mm(D) 80mm (H),6.3Litres
Max 22cm VGA card
Max 58mm CPU cooler with fan OR 43mm without fan(use case's 12cm/14cm fan 15mm thickness)
12cm/14cm fan 25mm thickness for VGA card
triple 7015 side fans module is optional ;
all fans are PWM controllable blowing fresh cold air into the case.
4 x 2.5 inche SSD/HDD in the SSD cage
all poweres by my 300watts or 400watts Archdeamon direct plug PSU.
standard DC psu solution is 300watts/400watts Brick+Archdeamon direct plug;
brickless psu solution is replace the SSD/HDD cage with a 400watts,500watts,600watts internal power module (80 plus platinum)+Archdeamon direct plug.
question - i see a rectangular PSU hole in the back of the case, but i also know that you sell circular GX16 jack PSUs.
can you modify this case before shipping, so that its DC jack hole is circular 16mm ??
guryhwa
G-Unique
Dec 23, 2016
164
962
the lately version is C14 opening,so,it is enough to make a bracket to adapt to any others dc jack
guryhwa
G-Unique
Dec 23, 2016
164
962
Where is the black PCIe coming from? Can you show what the CPU 8pin is connected to (looks like some kind of adapter)?
the MB is MSI xpower ,it has dual cpu 8pin ,i used one for cpu in,one for out and convert to pcie 6+2pin
Alxs
Is there a possibilty to have a psu version with the c14 plug at the extremity instead of the side? Like the flex atx psu? It would fit in many builds that way!
CC Ricers
2,234
2,557
I'm up for a HP AC-DC unit but just that part. I'm planning to use it with a Thin ITX board so I can supply full power to the GPU. Is it possible to just order the internal HP unit and have the 12V DC out modded for a 4-pin mini fit connector?
guryhwa
G-Unique
Dec 23, 2016
164
962
you will see it later
T_Tank
137
113
Now... can you make one of these tiny PSU combos power a vega frontier with a ryzen 1700 o.o?
bezzita
Hi @guryhwa,
I am upgrading my system GPU, I am interested to get these PSU Combo.
Case: NFC S4 Mini
CPU: Intel i7 7700k
SSD x2 M.2 NVME (500GB + 250GB)
GPU: Zotac GTX 1080 Ti Mini
CPU Cooler: Noctua NHL9i
Motherboard: Asus ROG Strix z270i
Could you please recommend which combo works best for my system? How much? How much would the shipping to Melbourne, VIC 3000, Australia will cost?
Thanks.
mrfess
Hi Bezzita,
I just ordered mine from gurywha, I did it by logging into his favorite chat app,
https://discordapp.com/
he is always online there and if you're truly ready to order and just need to verify a couple specs, I recommend hitting up the folks on there. The group of folks were nice enough to make simple suggestions for me before i spoke to gurywha. Gurywha will usually chime in and invite you to a private chat to seal the deal. Try to find out the power needs of all these components first from pcpartpicker.com - Someone on the forum recommended another site (better site to figure out the power) it slips my mind now. guruwha has his options and prices on this site on page one of this same thread. So steps to get this done would be
1 find out ur power requirements
2 check page one of this thread and get familiar which power options of guruwha u fall into and familiarize with prices
3 get discord app and check with the folks there and gurywha that u chose the right stuff.
Hope this helps
Reactions: Acalanata and lac29
lac29
67
40
Hi @guryhwa,
Case: NFC S4 Mini
CPU: Intel i7 7700k
Thanks.
I'm most likely going to do a similar build so let us know when you arrived an the specific options for the psu combo.
