Sorry for the double post, photos for reference...
What about our trustworthy friend fan grill? Or swap fans with the undermobo one (I dont know if it allows a full size fan though), assuming some performance lossSorry for the double post, photos for reference...
im not understanding this vertical placed fan...feels weirdSorry for the double post, photos for reference...
Hello! I was able to make it work with. a slim fan on the AIO (Corsair h60) AND the fan slot, and some struggle cable management. (Also my PSU is a corsair SF750) Basically:Sorry for the double post, photos for reference...
Custom cables. I got mine from pslateGuys
I just have no idea how this cable management is supposed to work out with a liquid cooler. Feels like I cannot support the fan, even if it was smaller. But regardless, the tubes just don't want to curve around the RAM and there's so much power cable I could choke.
Any suggestions?
@AlexTzone If the reply from UPS is not positive, what is the so-called "other" option?
So if steel is so small, wouldn't that mean I would be expecting an email regarding shipment within the next two days if all things go according to plan? I'm in batch 1 and the order is #13XX for steel going to Canada. Who else got steel?
And
Basically you need right angles off the PSU for every cable. You need to pull all the cables tight where possible to maintain that 90 degree bend. By using dual slim fans, you can wedge the AIO tubes between the RAM and the fan and hold all the cables in place with the AIO tubes.
- Insert the AIO first
- Install the GPU LAST! so that you can pull cables tight to the back where there's extra slack
- Run all of the cables between the two aio tubes so that the tube pushes the cables *inside* the case
- If cables have extra slack (i.e. Motherboard connector), pull the entire cable to the back of the case (GPU side) before inserting the PSU.
- When inserting the PSU, make sure all cables are bent to point *inside* the case
- Pull all cables with extra length towards the GPU side after inserting the PSU to make sure they don't fall in the fan blades
- Use velcro ties if needed to hold them in place
AIO cables holding in the CPU power cables and pump/fan cables
PSU and bending of cables to make it work
GPU side and extra slack being held in the mobo power cable
My take on your scenario: You need a slim fan as well above the radiator and then spend a lot of tie bending the cables correctly. You need to route the cables *between* your tubes, not behind them. Could you make this work with the regular-sized fan? Maybe. Is it worth the hassle? Probably not.
Other photos in case there are some helpful for you: https://drive.google.com/drive/folders/1yLFYYz2K0lbkV-u8ivEWrdZzcSvJmUK4?usp=sharing
Ooooh wonder what it is. Very curious.Also, while we wait...we've drafted an addon some will love and others will hateHowever, like with the rest of the case, perhaps we can fine tune it together
Posting pics later today or tomorrow!
That's even better that what i would have ever imaginedPRESENTING — THE DOCK
- Vertical MJOLNIR stand
- USB-C
- Front power button
Not sure which two-tone is best for Stealth, Dark and Steel respectively so feel free to let me know. Also tested have it as 1-tone but that looked really boring.
- USB-C
The thorzone thing could be a sticker - he can just sell the decal - I would buy![]()
I like this scene the most.
A full gear porn.
It's like Iron Man 1 suit scene.
When can I buy the aio with the Thorzone logo printed on it? Will it be considered with the gen4 card after the delivery is completed?
Question: for those who bought the booster cell - how is this configured?PRESENTING — THE DOCK
- USB-C
