I've done a bit of tinkering over the years in tinkercad with my RC hobby but I threw this together in about.. 6 hours during a slow work day
Now it isn't a perfect replica its got a layout rework and I'm not.. THAT good at perfectly making shapes in tinkercad.
Now for specs
--ITX layout more similar to the dan case with using a flexible riser to put the gpu on the back side of the motherboard. In this case this layout is flipped 90o
--Still will use a pico PSU or dc-dc like I believe the original did.
--2.5" HD bracket under the motherboard then 2x 2.5" drives on the other side in the lower deck
--Case fan is roughly the same dimensions as noctua's NF-P14 flx
--With cpu hight limit of 56mm maybe can inch that out to 58mm if I make the top fan bezel thinner
--slim dvd mount on the base
--205mm wide X 230mm depth X 190mm tall
--gpu reference is aprox. to a 1080 mini
still need to figure out how the secure the pcie slot at the connector have no clue there and the pci brackets at the back maybe something slide adjustable to keep the front of the gpu from sagging dunno. Also need to fiddle with the motherboard tray so it can slide out or make the mid section exterior removable to make it easier to service the motherboard an when building.
Would put this in concepts but I don't really plan on making this but if I knew a better way to export the tinkercad files to a more usable cad format I'll put it up for someone to make their own and heck maybe better!
This was just a fun exercise in recreating the little case as I loved how it looked but it was just not a practical case back in the day. That an I don't need a whole insane amount of computers running!
Now for specs
