So I'm planning a build in the MC600 but I have a few questions and figured this would be the place to ask. I've seen almost all the builds here in this case, but still need a little more info.
So in Runamok81's build he was able to fit a 25mm fan above his L9i, which is 23mm tall. Therefore anything 48mm or under should work, right? My plan (hope) is to use the Thermolab LP53 and swap it's fan for a 120x20mm Yate Loon. Which should also be exactly 48mm.
Also can anyone get me a measurement for GPU cooler clearance from the PCB when the GPU is flipped like in the Little Mac? I plan on using the Zotac 970 mini which has a very low profile heatsink when it's stock fans are removed and I'm hoping to fit a full 25mm thick fan in there.
Also any idea if a full 7.75" card will fit without extending the front panel? The PCB on the Zotac card is the normal length as a regular 970 mini but the heatpipes stick out an extra half-inch or so. I know it should be close and I plan on venting the front panel as well anyway but I'm hoping to still keep everything flush.
You guys might not know the answer to this last question, but any idea if their DIN/wall mounting plates can be put on and taken off without opening the case?
https://www.logicsupply.com/mtw100/
^^ Those. It looks like they just screw into the bottom of the case, but I could be wrong.
Thanks guys!
Thanks guys!
