Smallest Ryzen build (Logic Supply MC600)
TheHig
951
1,171
Cincinnati, Ohio
Thanks for the updates. Your temps don't seem worrisome if thats what you see after things are heat soaked. I'm curious if they are any different if the case is arranged horizontally. Maybe a couple of small fans exhausting out the top if you keep it vertical. Just spitballing really.
I have had really good results under volting my 1700 so maybe you could mess with that on the CPU side.
Really like your build. :thumb:
asymingt
Nov 11, 2017
