mac clone htpc
NFSxperts
112
53
I found this case on a chinese site, think its made by taidingcase.com/pr.jsp
It's a clone of the new cylinder Mac pro. Quality isn't bad, a few scratches on the curved panels but the internal frame is very stable.
More pics on ocn
http://www.overclock.net/t/1300645/official-usff-sff-club/1860#post_24386569
7,151
Interesting find.. still looks like a trash can though.. Still waiting on a coke mod XD
5,853
4,913
I personally like the new Mac Pro and admire it's accomplishments with what has been achieved on the inside than what the outside is about.
12-core CPU, dual workstation-class GPUs, dual PCIe SSD storage, quad-channel RAM. All cooled by a single heatsink and fan.
No polished single piece aluminium shell ? Meh.
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
freilite.com
We can tell by your profile pic :p
Jokes aside, I think this is a really interesting case, nice find!
IntoxicatedPuma
Customizer of Titles
992
1,272
Did the OP buy this case? I purchased it last September and still have it sitting in my apartment, but I had a lot of issues with the case. The front panel connectors were poorly attached and fell out, I couldnt find replacement connectors so right now it's just sitting in a corner of my apartment. Also the heat seemed kind of high in the case, I tried with different fan arrangements but basically if you use a video card, it blocks the top fan from sucking air out, and their isn't much room in the bottom to pull air in. I think a few revisions to the design and it would be much better. The build quality i felt was very poor, I cut my fingers on the outside panels and they scratch extremely easily.
IntoxicatedPuma
992
1,272
I sort of like these cases, but I feel like Silverstone should just release a more compact and updated and smaller FT03 Mini(make it SG05 size) . Round is nice but most components are designed for square PC cases.
DMF
Apr 12, 2016
Which video card were you using? According to the site, it only allows low profile single slot GPUs, no?
IntoxicatedPuma
992
1,272
You can fit a double slot card but the 25mm thick fan blocks it. Even with a 15mm thin Silverstone fan it won't work.
Getting the bottom fan out was also a bit of a pain - a 15mm thin fan works better for the bottom intake.
