Production M2427 - Cable Management Freedom
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Hi Jack. Thank you so much, I received my order today. Everything looks great, I'll try swapping cables this weekend. I'm currently just running a boot M.2 on my A4 but I'll get an SSD later for extra storage and I use the cable. I had not noticed the kit included the SATA cable with white wires that connects to the mini board, I also ordered the black short dual cable. Is there any difference or benefit of one over the other?
I was also going to ask you about the loose cable to plug into the GPU but I think I got it reading the other comment above. I'm running two 8 pins for GPU 2080 so I guess the closest connector below it should do.
Thanks again.
The only benefit is if you need longer reach or you prefer having fewer cables coming out of the psu.
loader963
666
571
Anyone here using the mini sata connector?
Late to the party, but i missed this question, and for my part I really dont have a need for it. But I guess it is nice you include it for others if they may need it.
Edit: [deleted] just opened it and understand now. Had a blank moment but this is an awesome device bro!
Reactions: Thehack
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Thanks! Makes cable management a breeze right?
Reactions: galzy and loader963
Pokepunch
Just got mine a few days ago after a small customs charge and Royal Mail deciding not to use the doorbell.
The unit is great and really cleans up the cable management! I found that the CPU 8 pin connector was a tight fit and took a lot more force to plug in than I expected. Other than that it's working without a hitch.
One question, is it possible to disable the led? It's pretty bright and clashes with my colours.
Reactions: Thehack
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Yes. Place a small piece of electrical tape to cover it. :D
polarium
35
Finally got the cables, really excited to try them out for my sentry tonight. Pics will come soon ?
After trying it out, NONE of the cables fit. All of them were too short, which was disappointing to say the least. The 24-pin ATX cable was too short, and while the CPU cables technically could fit, the cables directly go over the fan which is impossible as I am using a fan shroud. Guess I’ll be back with my original corsair cables. The PCIe cables I also tried (not in pic though) and it was too short, as it couldn’t even reach both slots in the PSU or GPU.
Here are the pics
For people considering using the cables for a Sentry, make sure your MoBo’s alignment fits (as in your CPU and power slot must be very upper-northwest, or it won’t fit).
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Here are the pics
I got your email btw.
It seems that this setup is like the perfect storm for nothing to fit. The Sentry offset for the PSU is more than most cases, and the Gigabyte Mobo has the farthest placed 24pin header I've seen. Most boards are closer to the middle.
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
Btw, please see your package for the set of 4 screws for your fan shroud. If for some reason you've lost it or it didn't come with any, let me know and I'll send you a new pack after vacation is over.
ermac318
655
510
Here are the pics
Is that the AsRock B450 or X470 board? The X570 or Z390 boards they have look like the ATX power connector is closer to the middle.
polarium
35
Yeah lol everything went wrong with it. But I’m definitely saving the cables though for a future build, maybe in an SM560 or a Dancase, we’ll see.
It’s the AsRock B450 itx board. I still think the ATX power connector still needs to be near the upper right corner, or it won’t fit.
rifter
28
35
How long after the holidays will there be new stock for the M2427 for SF “Platinum” Series? I couldn't find a stock notification system on the website. Thanks~
EDIT: On second thought, I'll just modify the gold version myself. I have to justify previously purchasing a crimping tool ?
ermac318
655
510
Updated stock for PLATs.
About to order one, but wanted to ask, the custom cable lengths you have with it that go from the PSU, are those lengths measured to a particular case? Are they sleeved or unsleeved? What do they look like?
Thehack
Creator
Mar 6, 2016
2,818
3,675
J-hackcompany.com
They are lengths design to fit Ncase and sandwich cases. I recommend getting the gpu ones. The cpu you should check the length you need, because there more locations for them. Use a string or something.
If you click on the picture of the cables when you are selecting them, you can see what they look like.
ermac318
655
510
Ah I didn't realize a picture showed up. I just ordered all of them hopefully they will work. I don't have the case yet to measure so hoping for the best!
