GPU Low profile, single slot 1050 Ti
Jonny727272
275
218
I haven't seen anyone mention this, but it's only DP 1.2. Doesn't that mean it can't use g-sync? I'm not sure of other limitations, but that is kind of a drawback :/
Thestarkiller32
152
102
it has to be a taipo because the 1050ti cames whit DP 1.3 out of the box...
maybe its because the number of ports that it is only supported if only one is plugged in
the Quadro P1000 is a 1050 with enabled DP 1.4 support
Jonny727272
275
218
Idk, I read everything I could find on the site and saw 1.2 multiple times with no mention of 1.4 anywhere.
chx
555
287
I thought all Pascal chips are DisplayPort 1.4 but what do I know
chx
555
287
Wow that markup, it is 330 if you get one directly as the thread notes.
Windfall
2,117
1,584
Jello
376
163
I hope we see some next gen AMD/Nvidia come in single slot low profile form factors.
chx
555
287
Don't have your hopes too high, so far every 20?0 card required more power than their similarly numbered predecessor. And yes, they are also faster but the previous generations have seen this shift as well, for example 670-760-950 are very similar in performance while power didn't increase and with the 950 it actually decreased. I think the 2050 will be like the 950 was at 90W or so. Perhaps the 2030 could be a single slot low profile and be as fast as the 1050 or if we get super lucky then the 1050 Ti. But we won't see progress.
The AMD RX 3060 is rumored to be a GTX 2050/GTX 1060 competitor at 75W but as we have seen with the 1050 Ti, manufacturers were not so hot on building a single slot low profile cooler for 75W cards. You'd actually need to see a significant power drop to see more of that.
Reactions: Jello and Windfall
