I've got some time on my hands again, so I'm going to get back to making more progress on my SketchUp (and Autodesk) files for my custom case I'm planning out.
Last time I was doing some work on the files one set of specifications I had struggled a bit to find. I need to work out the positions of vents, inputs and outputs on the "Corsair CX450M" / "Corsair CXM 450W" (names used interchangeably).
As far as PSU's go it seemed that the ATX PSU spec is quite vague. Once I have that spec nailed down, I should have pretty much everything I need. I might end up trying to grab some specs for some different bay caddies and I'll need to double check some fan thicknesses, but it shouldn't be too tricky to find them.
