Lian Li TU150 Build Thoughts
TMatzelle60
57
My TU150 gaming pc
Lian Li TU150
Intel i7-9700K
Noctua NH-U12a
Asrock Z390 Phantom Gaming-ITX/AC
Corsair Vengeance LPX 32GB
EVGA RTX 2080ti
Corsair SF750
2TB M.2
4TB M.2
will I have any thermal problems I will have a front noctua fan and 2 bottom noctua fans.
The CPU cooler has 2 fans on itand will be to close to mount a back fan
Cel
I just got this case today.
I'm running Ryzen 3600x cooled with a Noctua NH-U12A like yours.
Also running a Gigabyte 1080ti but instead of the original fans I have 2 x Noctua A12x15 mounted with stripes.
And finally I have a Noctua F12 in the front drawing air in (no fan in the back since the cooler is close enough (check out hardwarecanucks review).
The temps are very good.. 55-60 on the GPU and 50-55 on the CPU during gaming where the game requires about 90-100% gpu and about 40% cpu.
I've had a Ncase M1 and now more recently Dan A4-SFX, but this case is the case I like the most, of all cases I've ever had. Really happy with it!
amaximo
I have ran my TU150 now for 4 months with little to no thermal issues. Its my primary system for both productivity, re-coding and some gaming. Awesome portable case that gives me some luxury of mobility when ever I need to use it away from home.
Lian Li TU150
Asus ROG (X570) Crosshair VIII Impact
AMD Ryzen 9 3900x (average temp under productivity use 65c)
Corsair LPX 32GB (2x16GB) 3200MHz C16 DDR4 DRAM Memory Kit, Black (CMK32GX4M2B3200C16)
3 Noctua NF-A12x15 PWM Low Profile Fans (1 on the front 1 on the bottom of the case and 1 on the inside of the radiator)
Cooler Master MasterLiquid LC120E RGB
EVGA RTX 2060 XC Black Edition Gaming
XPG SX8200 Pro 512GB 3D NAND NVMe Gen3x4 PCIe M.2 2280 Solid State Drive (Operating system)
XPG SX8200 Pro 512GB 3D NAND NVMe Gen3x4 PCIe M.2 2280 Solid State Drive (applications and Games)
ADATA SU800 2TB 3D-NAND 2.5 Inch SATA III (data storage)
mb67
40
I built a Ryzen 9 3900X system in the Lian Li TU150 as well, but I didn't have it long enough for proper testing: It was given away for a charity event.
Ryzen 9 3900X
ROG Crosshai VIII Impact
Zotac RTX 2070 Super Mini
16GB G Skill Trident Z RGB 3600
Corsair H75 AIO in Push/Pull
Corsair LL 120mm RGB fans x5
Samsung 960 Evo 1TB nvme m.2
Corsair SF600 Platinum PSU
Reactions: amaximo
fabio
Shrink Way Wielder
1,855
4,276
Hey! I've just finished my TY150 Setup, and did some AIR Cooling Test!
Soon I will post Pictures and comments. Here the setup:
LianLi TU150X, the version with the full aluminum panels and the opening to help exhausting from the GPU
Asus Corsshair Impact DTX
AMD Ryzen 3950X Stock, Offset VCORE - 0.100
Corsair 2x32Gb 3600MHz C18 at 18-20-20-40-64
Nvidia Titan RTX
Corsair SF750 with Stock cables
Intel 905p 480Gb
Samsung 970 Pro 1Tb
Samsung 860 Pro 2Tb
INTAKE Noctua A12x25 with LNA with stock dust filter
Bottom 240mm dust filter.
I've tested the Noctua U12A and the D15S with 1 and 2 fans, with the general flow of FRONT INTAKE, REAR EXHAUST.
BIOS Fan Settings: STANDARD
Here the results after running 3 times CB R20 and the Benchmark Demo Scene with Blender 2.81a.
NOCTUA D15S 1 FAN (Stock A15)
NOCTUA D15S 2FANS (Stock A15 + A12x25 with LNA)
NOCTUA U12A (Standard mount, with the RAM completely cleared - The left fan stay just above the VRM and Chipset Fan)
NOCTUA U12A (180 Degree - Same Fans Direction, with the chipset and VRM fans cleared now)
I stay with the U12A 180 degrees!!
Jpdots
Nvidia Titan RTX
Intel 905p 480Gb
Samsung 970 Pro 1Tb
Samsung 860 Pro 2Tb
Hi! Awesome testing! Newbie here.
so are you sticking with the u12a cooler now? I’m stuck between these 2 coolers and don’t know which way to go. Thanks to this I saw that u12a is better. I wonder why and how. A lot of people is saying d15 is better.
Btw, I’ve seen some setup with d15 with 2 fans + another 1 in the rear exhaust. Any idea how is this possible?
thanks!!
raflex
Hi all,
Nice built Fabio!.
I was thinking to assemble a similar system with an 240 mm AIO, a Ryzen 9 3950x and the asus rog crosshair VIII impact MB on a NCase M1.
Unfortunately, Ncase M1 is not easily accesible in my country.
Then, the built on the Lian Li TU150 with air coolers a seems pretty nice alternative too. Just two questions:
What do you mean with a Noctua NH-U12A 180 degrees configuration? Could you post some photo ;-)? This cooler is symmetric, isn´t?
Did you have any problem with the length of the stock cables of the SF750 PSU to plug them on the mini-ITX Asus rog Crosshar VIII impact mobo?
I was also considering to use an NH-U14S cooler for RAM cleareance but...Fabio made me doubt if it would be better the NH-U12A :-)
Thanks folks!!!!!
raflex
Hi again,
I almost forgot it... what are the GPU thermals (Titan RTX) on this case with a tempered glass window? Have you tested it?
Thanks!!!
