Hi everyone,
I don't have much time currently, but I just want to share my current pc, that I build a few weeks ago, with you. I didn't take pictures while building so I can't do a real Build log, so there are only a few pictures for now.
But first, my parts:
Lian-li PC-Q01A
I7 6700k delid @4.5Gz with 1.265v (might try more, but I just don't have time currently)
Noctua NH-D9L with 2 Fans
Zotac 1070 Mini
Asus z170I Pro Gaming
2x 16 GB GeIL Dragon Ram 2133Mhz (was the least expensive I could get)
Corsair 450w SFX
500GB Intel p600
500GB Samsung 850 Evo
240GB Intel 520
Aqua Computer farbwerk RGB controller for the LED on my desk
If you are worried that the power supply might suffocate with the solid side panel on, I'm too, but it seems to be fine as far as I can tell. And the RGB strips gives the PC a slight underglow
I also monted 2 80mm fans on the back.
I used a SilverStone PP08 SFX Adapter to give additional clearance for my Noctua NH-D9L.
And my Intel 600p used to overheat at first, but those thermal pads work wonderful by transferring the heat to the backside of my case.
Edit: How it looks like when it's running. The LEDs change their colors depending on system temperature.
I managed to keep the temperatures around 70-77°C on the GPU and 70-80°C on the CPU while stress testing. While gaming the whole system sits around 70°C, but the CPU is usually 10°C cooler than the GPU. The best thing about this little PC is, that it is not audible while doing web browsing and office work
That's it for now. Since I'm busy currently I might not answer to frequently and fast which I'm sorry for already.
Thank you for reading my first post here
Lian-li PC-Q01A
Zotac 1070 Mini
Corsair 450w SFX
500GB Intel p600
240GB Intel 520
