Concept Lejonny custom case
lejonny
Hi,
I am lejonny,
For I long time now, I've been watching the ghost s1 from Louqe.
Love the idea of a sff case with AIO support.
The only problem I have is the availability and the high price.
So I made my own case and started building it from scratch...
I made the 3D files. The corners of the case will be 3D printed and the sides, top and bottom plate will be lasercut by the company I work at.
The design is very similar to the ghost s1, besides that my design supports 3 slot GPUs and a thicker radiator.
All metal panels will be secured using a variety of m3 screws. The GPU uses a 300mm pcie extender.
Front USB 3.0 will be installed as well.
I plan on using very strong components to see how temps will do.
I will be updating you and eventually uploading the 3D files for everyone who wants to build my case.
Reactions: raksan
lejonny
Here is a picture of my 3D concept. You can clearly see similarities to the ghost s1.
Following parts will be used:
  • CPU: I7 6700k
  • MB: ASUS Strix z270i
  • GPU: GTX 970 (GTX 1080ti)
  • RAM: Kingston ValueRAM 16GB 2400Mhz
  • PSU: BeQuiet SFX-L 500W
  • CPU COOLER: Arctic Liquid Freezer 240mm
I'll keep you updated!
Reactions: rosinbole
