My understanding of the merger unit is that it should allow you to use dual HDPlex internal AC/DC adapters at the same time. Not impossible to use an external brick with it though, just need it have a compatible electrical output. Using the 300 watt AC/DC internally in the new S4M is still an issue. Josh explains why in his latest video going over its features.Cheers mate! Sad but completely understandable!
Would it be possible to, perhaps with the upcoming Dynamo Merger, combine Dynamo Mini + Dynamo 360 with an internal HDPLEX 300W AC-DC and an external Dell 300W brick? That way I can choose for each GPU generation to either go big and get a GTX XX80 but will require external brick connected, or go smaller and externally brickless but only have support for say GTX XX60?
If I understood the meaning and purpose of the Merger correctly that is![]()
