CPU KL Pentiums have HT!
6,591
This is a rather weird decision. Does this mean KL Pentiums are just i3's with less cache? Kinda makes the (non-K) i3's not worth it as the price paid to improve perf over the Pentium would be...silly
(Looking at the pricing on the site, it looks like 30% premium for 1MB of L3 cache improvement and similar clocks)
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
Hmmmm... the Pentium G4620 is looking rather appealing now. I was planning to get an KL i3 but now I may have to rethink that.
5,570
4,778
I kinda wished they kept the HT off of the Pentiums or atleast have non-HT models. Not everything is better with more cores, especially single-core stuff. But seeing as AMD and Intel are going this way, it might not be a point, for the future.
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
Why? HT doesn't add more cores? Also. I don't see how adding HT is detrimental. Until you start hitting thermal headroom adding more cores don't affect single core performance.
Brokoii
31
30
You can always disable HT in the bios.
Reactions: ricochet and CXH4
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
For example the new KL Pentium G4620 would leaving HT "ON" actually lessen this Pentium's performance on single threaded apps/programs?
775
758
It's only with lightly threaded applications that hit the scheduler hard, does hyper-threading adversely affect the performance. I have seen benchmarks of games running better on an i5 than an i7, but just barely.
Reactions: ricochet
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
So a KL Pentium G4620 would perform better at single-threaded apps (email, internet browsing, office word) with the HT turned "OFF"?
775
758
If you have a lot of database calls or something else that requires a lots of I/O, the would be very taxing on the scheduler that manages the activity for both threads on a core with HT. I doubt typical email, browsing, or productivity apps will have any noticeable difference.
Reactions: ricochet
ricochet
SFF AFFLICTED
Oct 20, 2016
547
345
Thank you for the explanation; understand much better now after researching CPU "scheduler". Cheers.
BirdofPrey
Standards Guru
Sep 3, 2015
797
493
HT is only really going to be detrimental if CPU is at high utilization.
Hyperthreading (if you want to do some research, the technical term is Simultaneous Multithreading) does not actually change the computing resources of the core; what it does is allow more than one thread to share those resources since, often times, each core isn't 100% utilized.
If I am remembering correctly, Skylake (and by extension Kaby Lake) has 3 Arithmetic Logic Units (ALUs) and 2 Address Generation Units (AGUs). If one thread only needs to use 2 of the ALUs, that leaves 1 available for use. Whether or not HT is on won't affect that. You only start to see problems if both threads want to use 2 or 3 ALUs (granted it's more complicated than that, some instructions only work on certain ALUs/AGUs and the threads are sharing a cache), but it still generally works out the same: You're not going to see much difference on a per-program basis, if you do you need to rethink your choice of CPU.
Reactions: ricochet
IntoxicatedPuma
Customizer of Titles
990
1,266
Just curious then, if I were say rendering a video on Adobe Premiere or something, would a G3258 @ 4.5ghz outperform a 3.8ghz Haswell i3? Since the CPU usage should be around 100%.
I'm not too familiar with this as well so I usually just assumed HT doesn't have many drawbacks.
Reactions: ricochet
Therandomness
226
268
They're missing AVX, AVX2 and some other instruction set though.
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,801
4,127
guilleacoustic.wordpress.com
Intel CPUs not reached Intel Chipsets on the non-sense hall of fame. It was already impossible for someone who doesn't follow tech news to choose an Intel chipset (too many of them) ... but now it will also we impossible to pick the right CPU.
Celeron are/were just Pentium with 1MB less of cache. Now Pentium are i3 with 1MB less of cache ..... Intel has too many chipsets, too many CPU with sometimes only 100MHz between each of them). Some CPU are more expensive than one with a faster base frequency ... because it can turbo a little higher (i5-4570 3.2 / 3.6 @ 239€ VS i5-4460 3.2 / 3.4 @ 194€ .... 23% premium for +200MHz turbo and no base clock boost).
Reactions: CXH4
