**EDIT:
This started as an advice thread on a Phanteks Shift XT build. But after tinkering a bit and finding a Jonsbo A4 for a nice price I decided to build in it instead.
Build photos from post #11 onwards
Hi!
So getting ready to build this on a Shift XT: 7800X3D, 32GB DDR5, RTX4090, B650E-i mb
The Shift XT can handle a 38mm thick 240mm radiator up top with T30 fans, after some light mods and 3D printed parts.
Wondering what would be the best bet:
I can get the Inno3D iChill Black 4090 with AIO for less than 100€ more than the Ventus. It seems like a better card which is much quieter and boosts higher. This AIO was done with Arctic so it uses the same 240x38mm rad as their CPU AIOs. The pump and block isn't a crummy hybrid system with a fan (like MSI's Suprim Liquid) but instead a traditional full coverage block.
Watching Buildzoid's video on aircooling the 7800X3D () was what gave me this idea as the CPU should, in theory, pump out much less heat into the case than the 4090 in pure gaming loads and the Noctua heatsink should be able to handle it nicely. I don't think it would perform much better with an AIO when an aircooled 4090 Ventus might transform the case into an oven.
The AIO 4090 on the other hand will run a bit faster, much quieter and will also not heat up the case as much leading to better thermals... in theory?
What do you guys think? Should I go with the aircooled 4090 and AIO the 7800X3D or the other way round?
Custom loop is in the plans but only further down the line. Need to know the case better, plan it out nicely, and save up for it as the 100€ difference for the 4090 AIO could barely afford proper fittings.
Thanks
Hi!
#1: Watercool the 7800X3D w/ Arctic Freezer II 240 AIO and get an aircooled 4090 FE or (most likely due to pricing and availability) MSI's 4090 Ventus 3X.
#2: Watercool the 4090 and put a Noctua 70mm aircooler (NH-L12S) on the 7800X3D.
Thanks
