is ID Cooling IS-60 more powerful,
than CryOrig C7 copper ??? - http://www.idcooling.com/Product/detail/id/19/name/IS-60
But when compared together, IS-60 beats C7 Copper by 2-3 degrees. Not much thermally.
only 2-3 degrees is not worth it.
I'm about to try the AXP-100 copper which is maybe the only remaining alternative to the IS-60 at the moment in that size/height category, it's damn expensive and probably overpriced (guess that's the purpose of the fancy copper coating!) but still more affordable than an IS-60 on eBay from scalper's hands.
If you read around users/builders experience a lot, you'll see that it's common knowledge that the IS-60 performs better than the C7 with whatever silly coating.
I'm no metallurgy expert, but I've seen this guy dremel its own to increase clearance and what's beneath didn't look like copper.AXP-100 Full Copper does not have a coating of copper but it is actually full copper. It weighs in at 600g (vs 320g of the regular AXP-100 RH).
The RH is taller though, wouldn't fit in the Node 202 without case modding and honestly where I live only 4.5eur cheaper than the copper version, so I've got the latter.AXP-100 RH is a very viable alternative to the full copper version.
But, of course, the full copper version has that luxurious illustrious copper look, which can be irresistible.
IMHO, that's referring to one comparative review, personally I wouldn't trust it's always just 2~3 degrees in all situations, with every cpu/board/case.ok, but " by how much " is the point.
if its by only 2-3 degrees, why should i use it ???
you can just swap its default C7 fan, with a Noctua fan, which solves the noise issue.
is that those air coolers, in SFF cases, no matter how many pipes and fins and powerful fans, aren't efficient enough for cooling many modern CPUs, and in particular not the unlocked.
Either we limit our SFF builds to more temperate CPUs (65W locked and such) , either we go water cooling from day-1 building, but air coolers ? even for mildly powerful builds they are about obsolete.
i know from personal experience that both a BlackRidge w/ 120mm fan, and a CryOrig C7 copper w/ Noctua fan swap can cool a i7-9900KS perfectly, if you have an airgap of at least 3- 4mm, between its cooler and sidepanels.
I'm more of an air cooler person myself, so this is interesting, because if i remember correctly, C7cu is only rated for 115w. Do you have any benchmark data you can share that can support your experience?
if you look at this video, it basically confirms what i'm saying about a BlackRidge :
as for a C7 copper, i'll try to get someone to put it in a video, later in june or july.
also, note that i'm not talking about a stock BlackRidge or stock C7 copper. you need a BlackRidge w/ 120mm fan & VLP Ram, or a C7 copper with Noctua fan swap.
Because thats your argument when someone said that the is60 will cool it better, which again answer your previous question
Anw, back to your original question, between the 2, if space is not an issue, I'd go with IS-60 instead of the C7cu.
I will be cutting Noctua NH-L9x65 to fit it inside SM550, which has 55mm clearance to cool 5900X![]()
What is the case you are looking at?
Why do you think so?there's no way you'll be able to cut 10 whole millimeters off successfully.
