Cooling ID Cooling IS-30
scatterforce
325
196
Reactions: Soul_Est
KMPKT
3,380
5,918
That's quite an impressive design. Really doubt it's going to cool 100W terribly well but will be really interested to see results.
wesbl
173
115
Just not enough mass, surface area. It'll be good for thin-ITX though. No point in comparing it the L9 or C7.
I'm not sure, look at the lp cpu cooler roundup in this forum, the scythe s950m beats the noctua l9i in every situation.
Thehack
Creator
2,749
3,532
J-hackcompany.com
I see it edging out the L9, while loosing handily to the C7. So I guess it may edge the L9? But I highly doubt it.
Obviously, It won't match a 47mm cooler.
Reactions: wesbl
tnysff
65
Checking the specs of the IS-30, it has a footprint of 93x100. That 100 has called my attention. In the past I built some ATX systems and some mATX ones. I never run into a problem with cooler sizes. Now I am a novice in the ITX format and I wonder if the ITX specs dictate clearances around the CPU that would ensure all coolers designed for the format would fit. Will that 93x100mm work with all m-ITX boards ? Is there any way to know before hand?
Stevo_
449
304
I'm more worried about the VRM clearance in the 93mm side, looks real close to the IO shield side on my MSI B450 mobo, won't know for sure til I try it though
paylesspizzaman
Apr 22, 2019
Would love to here if this worked out for you or not? I'm considering buying this cooler. I need to upgrade from an Asrock Q2900-itx board to an i3 8th gen and am super limited on space. Also, $25 sounds better to me than $40 for the noctua.
Stevo_
449
304
Should be this week
Stevo_
449
304
Not going to work on my MSI B450 mobo, there's 2 VRM components surrounding one hole, could not get lined up. I think the stock 2400g cooler will work without the shroud, at least it fits.
EDIT: It appears that the AMD adapters wre made with adjustability and length to fit previous AM3 96mm hole space, but this makes the adapter too long for the AM4 90mm space which has VRM components surrounding one hole. At best I could fit one end but not the other at the same time.
paylesspizzaman
Apr 22, 2019
So you have no way to test it then? Are you going to return it, or what's the plan.
Stevo_
449
304
Correct. I'll probably just sell it on here, got a bunch of stuff I'm getting ready to unload virtual garage sale.
The stock wraith stealth is a bit too tall even without the shroud, but I found this Evercool Titan fan same diameter and hole dimensions but 15mm that should bring it all home.
https://www.ebay.com/itm/Titan-TFD-...411521?hash=item4d44a90d81:g:PhMAAOSwTdJXRTPC
tnysff
65
Stevo, wouldn't this be a problem with many ITX boards? From your experience, do you think it would also happen with the ASROCK B450?
