Prototype Introducing the Chimera CX2
karaju
Really looking forward to this case.
I am looking for a small ATX case and was about to order the Cerberus X before noticing the CX2.
This one looks like it will have a lot better airflow than the Cerberus.
gintasr
Just picked up an ATX motherboard for the first time in at least 5 years in anticipation for this case with an NH-D15. Hoping for better thermals and noise compared to the ghost s1 and ncase.
Reactions: rayuma
QuantumBraced
507
358
Wouldn't it be better to have the I/O at the bottom like with the M1? I feel like 90% of people will put this on their desk. Would be much better to have your headphone cable come out the bottom.
Reactions: gintasr
WHATT
Will there be an option to lay the case down on its side? I assume all I would have to do is attach feet to a different panel, but I'm just curious if this has been thought of at all.
VegetableStu
1,949
2,619
the video mentions (at 6:53) that some SFX PSUs may come with a 24-pin and EPS cable that may not be able to reach from the bottom (which is why there weren't any shots of cables), and earlier in the thread (if i remember right) the creators mentioned that they're working to address this (and the other fitment points brought up in the video)
you should really check the video out (above)
THUMPer
107
58
I watched the video when it came out. You expect me to remember everything I watch? ? ?
With the PSU on the bottom I could see that being an issue. But with the PSU at the top front, it seems like it may work.
nemesis429
27
I reckon a good optional idea would be a top panel to allow two fans on top e.g. if you wanted to have dual rads with PSU at bottom.
VegetableStu
1,949
2,619
it's covered earlier in the thread, they mentioned strictly adhering to a closed-off top to ensure optimal front-to-back airflow (unless something changed between may to now?)
