Motherboard Industrial Motherboard Thread
kotproger
136
130
vk.com
FUJITSU Mainboard D3654-B Mini-STX
The answer of the Russian distributor (prom-pc.ru):
There are 2 ways to get it.
1. Purchase a multiple of 20 pcs. in OEM packaging (board in antistatic package, driver disk, nameplate). Up to 12 weeks. Price with VAT for 1 pc - 157 € (but the order is a multiple of 20 pc)
2. Purchase 1 pc. in the kit kit. This includes a motherboard, a case for it SMARTCASE S520, an active cooler, COM2 cable, USB C cable, internal speaker set, WiFi set. Up to 12 weeks. Price with VAT for 1 pc - 250 €
The case is like this
kotproger
136
130
vk.com
SBC PROFIVE® NUCV on AMD Ryzen™ Embedded V1000
Currently, the manufacturer is in search of distributors of its products and retail sales are not planned. It is possible to update information at the beginning of 2020, but by then a Zen2 embedded representative will already be available.
Reactions: thewizzard1
Windfall
2,117
1,577
So if I understand correctly:
If you want just the board, the MOQ is twenty units, and if you don't want 20 of them, you can buy a kit with a case with the MOQ being 1?
Cool board. Wonder what the cooling solution looks like!
kotproger
136
130
vk.com
Yes, but this is only true for the current distributor - prom-pc.ru . Their list can be seen at Fujitsu in the where to buy section.
Similar to NUKs from Intel) The form factor is the same.
kotproger
136
130
vk.com
ASRock STX-1500 on Intel® 11th Gen (Tiger Lake-UP3) Core™ Processors, up to 28W
https://www.asrockind.com/en-gb/STX-1500
Processor System
CPUIntel® 11th Gen (Tiger Lake-UP3) Core™ Processors, up to 28W
-STX-1500P (i7-1185G7E, 2.8GHz, 28W)
-STX-1500M (i5-1145G7E, 2.6GHz, 28W)
-STX-1500V (i3-1115G4E, 3.0GHz, 28W)
ChipsetMCP
BIOSAMI SPI 256 Mbit
Memory
TechnologyDual Channel DDR4 3200 MHz
Capacity64GB (32GB per DIMM)
Socket2 x 260-pin SO-DIMM
Graphics
ControllerIntel® Iris® Xe Graphics for i7/i5 CPU
Intel® UHD Graphics for i3 Processor
HDMIHDMI 2.0a
Max resolution up to 4096x2160@60Hz
LVDSDual channel 24 bit up to 1920 x 1200@60H
eDPeDP 1.4 Max resolution up to 4096x2304@60Hz
MultiDisplayQuadruple Display
Expansion Slot
M.21 x M.2 (Key E, 2230) with PCIe x1 ,USB 2.0 and CNVi for Wireless
1 x M.2 (Key B, 3052/3042/2280) with PCIe x1 / USB 3.2 / USB2.0 and SIM for 4G/5G
SIM Socket1 x SIM socket connected to M.2 key B
Audio
InterfaceRealtek ALC897 HD , High Definition Audio. Mic-In / Line-Out
Ethernet
Controller/ SpeedLAN1: Intel® I225LM with 10/100/1000/2500 Mbps
LAN2: Intel® I219LM with 10/100/1000 Mbps,
Connector2 x RJ-45
Front I/O
USB1 x USB 3.2 Gen2, 1 x USB2.0
Audio2 (Mic-in, Line-out)
HDMI1 x HDMI 2.0a
Rear I/O
HDMI3 x HDMI 2.0a
Ethernet1 x 1 Gigabit LAN
1 x 2.5 Gigabit LAN
USB2 x USB 3.2 (Gen2), 2 x USB2.0
DC Jack1
Internal Connector
USB1 x USB 2.0 (1x2.54 pitch header)
COM1 x COM (RS-232)
1 x COM (RS-232/422/485)
GPIO4 x GPI, 4 x GPO
TPMTPM 2.0 onboard
LVDS1
eDP1
SATA PWR Output1
Speaker Header1
Storage
M.21 x M.2 (Key M, 2242/2260/2280) with SATA3 and PCIe Gen4 x4 for SSD
* Shared with SATA3_0
SATA2 x SATA3 (6Gb/s)
Watchdog Timer
OutputFrom Super I/O to drag RESETCON#
Interval256 Segments, 0, 1, 2, ...255sec
Power Requirements
Input PWR12~28V DC-In with 4-pin wafer PWR cable or DC Jack
Power OnAT/ATX Supported
- AT : Directly PWR on as po wer input ready
- ATX : Press button to PWR on after po wer input ready
Environment
Operating Temp0ºC ~ 60ºC
Storage Temp-40° C ~ 85° C
Operating Humidity5% ~ 90%
Storage Humidity5% ~ 90%
jpmomo
38
51
Half size? How about Half-SSI :D
should have my latest build finished tomorrow. based on the following mb (supermicro h12ssw-iN) with a 64c amd epyc 7742 and a dual port 200GE mellanox nic:
oddball mb size but will be used in a custom sff chassis for 7x24 use. Pictured next to an s4m for comparison.
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
2,801
4,127
guilleacoustic.wordpress.com
Out of curiosity, what will it be used for ?
Dunedan
26
E.E.P.D just announced the successor of the SBC PROFIVE NUCV, mentioned earlier in this thread, the SBC PROFIVE NUCE:
https://www.eepd.de/boards/single-board-computer/sbc-profiver-nuce-x86/
The major changes compared to the NUCV seem to be:
- Zen2 based APUs
- DDR4-3200 with ECC support
- 2x 2.5GBit/s LAN, instead of 2x 1Gbit/s
- no microSD slot anymore
- front USB now USB-C with support for DisplayPort alternate mode
- eDP instead of LVDS
- two instead of one SATA ports
- additional Infineon TPM 2.0 module
Pretty sweet board, especially given its small NUC dimensions.
kotproger
136
130
vk.com
- Zen2 based APUs
A worthy receiver! But it's a pity that such boards are difficult to catch in the public domain.
