Hi all,
Tinkering with using some server grade components to dive into water cooling on either my Dan A4 or plunging into the Velka 5. Inspired by @petricor amazing NFC 4090 build. If I stay below the 4090 and 7800x3d I figure I can make things slightly less complicated due to less power/heat (apart from my budget constrictions).
Now to my question:
On paper the Alphacool 120mm Industrial fan has about twice the static pressure of the acclaimed Noctua 120mm Industrial at 49 vs 43 dB. Has anyone used/compared the two?
best,
M
Now to my question:
best,
M
