Advice Ideas for mounting HDPLEX 250W GaN in Lian Li TU100
ASCii
(ツ)
73
55
Originally I had planned to mount the HDPLEX 250W GaN via the existing holes on the bottom of the case as they matched the hole pattern on the HDPLEX perfectly, however due to the protruding side panel plastic clip this wont be possible.
Any ideas...Thermal Tape, Dual Lock Velcro ?
BaK
964
956
Some standoffs to put the PSU above the plastic clip?
Reactions: ASCii
ASCii
(ツ)
73
55
Well I think I will be going the custom route, I found a metal fabricator rather close to me to cut out a custom mounting plate matching the base of the case, along with a SFX bracket seeing that HDPLEX is out of stock with no ETA.
