So I want to do a test with the C7 Cu that I just bought. Problem is I need someone who can 3D print.
I mentioned in previous forums that I am trying to make a small pc using the "OG" 1st gen xbox 360 and I have a Cryorig C7 Cu still in its box but never been used.
My delema is that I don't want to use the fan that comes with the unit because it does not meet my cooling needs as it is gonna be in a problem child case.
On the forums I did find a post that someone has made 3d printable fan brackets that can fit a 92mm and a 120mm. If someone could 3d print it out and send it to me, I can do some tests inside a Phanteks Enthoo Pro for the time being and see what kind of performance I can get.
The fan I am thinking of going for is a Delta 25mm high fan with a 4 pin pwm. Noise isnt my main concern since I can adjust the fan speed accordly in the BIOS based on temperatures.
https://www.newegg.com/Product/Product.aspx?Item=N82E16835706035
