Acrylig fan duct for Noctua NF A-9
deadline
161
67
Hi!
I was wondering if anyone could help me draw an acrylic fan duct _excactly_ like this one? The creator isn't active on the forum, so can't get hold on him.
It's for a 92mm fan (mounted on top of C7 cu). And they need to be able to be cutted in 3mm and 5mm respectively.
I will off course pay you for the DXF files, and share them here if anyone's interested. :)
Kind regards,
//Stef
Reactions: garyroks
el01
770
588
Hi!
Kind regards,
//Stef
Imma need some dimensions (I assume fan holes are M4, but what about for the rest of the dimensions. Reverse engineering will be a PITA without them)
Is it OK if I provide an SVG (or at least something like a .STL?)
I can provide them for free (FOR THE GOOD OF THE COMMUNE!) (or send me the cheapest CPU you own ;) ). I also won't do rounded edges since those won't be very useful.
N
Narwhal
Guest
Hi!
Kind regards,
//Stef
does it actually help with cooling and how do you attach the fan on the c7?
