DwarfLord
51
29
Now we need a 80w ac-dc updated to 120w to handle a 2400g, GGNNNIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII
Edit : wait a minute, don't tell me the hdplex 160w fits into it ?
Choidebu
"Banned"
Aug 16, 2017
1,196
1,200
Hdplex 80W: 121.4 x 30 x 40 mm
Hdplex 160W: 150 x 52 x 40 mm
3cm longer and 2.2cm thicker (that's what she said)
Windfall
2,117
1,577
The problem with the 160 is that then you can't use the onboard front IO...... Maybe meanwell PSUS?
Windfall
2,117
1,577
Possible with meanwell. It's about 102mm deep, which gives you about 40mm to install power entry.
It doesn't look like the AMD STX has internal power in though. Seems only barrel connector.
I know, I have a passthru hole built into the case.
Windfall
2,117
1,577
Will post pic of 3d-printed base ASAP. The printer upscaled it (I think) by half an inch, or for the british, 12.7mm. Pretty significant. Well, I'll do a test fit, revise the model, and then:
A few more 3d-printed models
Actual Sheet metal prototype
and then production (hopefully).
Reactions: owliwar
CC Ricers
2,216
2,522
Is this case still being developed? Don't know if you have any prototypes being made yet.
Windfall
2,117
1,577
Yeah, just working around power delivery, and trying to source a custom cable. (4-pin from HDPLEX to barrel plug)
If you have ideas, I'm open.
Need a CHEAP sheet metal shop, though @VELKASE Michael might have me covered there.
CC Ricers
2,216
2,522
Cheap and sheet metal? Hmm, I can't think of any as I've only dabbled with manufacturing services that let you upload your designs directly. Bigbluesaw.com offers sheet metal cutting services but they don't do metal bending. But I agree to contact VELKASE first since he's already on these forums :)
Given the smaller size of the STX and also power requirements I was thinking how well it would work in a small enclosure similar to the Arctic MC101
It is only 30mm tall and I don't know how slim you can make your case, how tall the I/O and RAM sit in the embedded Ryzen/Vega boards. But I was imagining some basic aluminum heatsink with a blower fan placed to the side of it. Is passive cooling an option for the 25W embedded chips?
For something that consumes little power our opinions may vary for solutions. This HTPC uses an external power brick but for low wattage I'm personally okay with that. But others won't be of course.
Windfall
2,117
1,577
Now that we have AM4 STX nearly here from Asrock, is there any interest in these cases?
Would a version WITHOUT HDplex 80w support be preferred?
What about a CNC machined fanless version?
I'll have a working VMC soon.
Reactions: mrp0p1nfr3sh
mrp0p1nfr3sh
67
44
Wait you got pics for the case?
Windfall
2,117
1,577
Thanks love the way it looks are you thinking about doing a batch order for a case without the internal power adapter?
Like just having it with no room for a PSU?
The PSU can be bought from HDPLEX, it's the 80W ac-dc.
mrp0p1nfr3sh
67
44
Yeah i have an hdplex build. But im planning on swapping the case out on the Asrock deskmini A300. Since that has an external power brick im ok on sizing i just dislike the look of the stock deskmini.
TristanDuboisOLG
81
21
Quick question, I know that you said that the case is still just a CAD picture because of next to no interest, but I was wondering if anything has changed since the arrival of the Onda B320? I have one on order and your case design looks great!
Windfall
2,117
1,577
This is an STX case, not thin-itx. It's still a CAD model, but with the A300 STX from Asrock now out, I wonder if there would be some interest
