Cooling Homemade cooler - GPU needed
BaK
967
958
Hi guys,
I am almost ready (read weeks away) to test an homemade custom GPU cooler.
Could you point me out a GPU that will be worth using, i.e. a GPU that gets hot easily?
So that if my cooler can manage to keep it cool, it will also be ready to handle the latest GPUs?
I would of course be glad to check what I can get with a 1080ti or a 2080ti, but they are both too expensive for a first test.
That's why I was thinking about an old GPU, preferably from NVidia, that I may find as second hand for cheap, like under 300$.
Any idea?
ignsvn
By Toutatis!
1,729
1,673
Nvidia... Hmm other than 980Ti mentioned above, perhaps 780Ti?
If AMD, then perhaps R9 Fury, R9 390X, or 7970?
Reactions: BaK
nick_w
27
29
The gtx 480 ran quite hot, if you just want something that can generate a lot of heat.
you can get them for about $40-80usd on ebay
BaK
967
958
Weird!
But alas it looks like I am a bit late as the guy wants to keep his last card.
I tried to sign in at hardware.fr anyway but here is what I get following the link they sent me:
Everything should be fine with my comp though.
Will try again later from home, who knows...
EDIT: an admin had to validate my account, just posted a reply there
I will also have a look around for a 480 or a 780Ti, thanks everyone!
