High perf gaming rig suggestions for Dan A4 (v4.1)
brewski
Picked up a Dan A4 (v 4.1) over holidays as a bit of an impulse buy. Hadn't even put any thought into parts at the time.
So I'd appreciate some guidance here as I want to get the most out of this case. I'm looking for as high a performance gaming rig as I can fit in it.
A few notes
  • I live in US
  • No standby parts, no reusable parts. Strictly rig, no peripherals or otherwise.
  • No budget, just restricted to the dimensions of the Dan A4.1 case
  • GPU that can drive games comfortably on ultra-wide resolution. Not after 4k max settings or anything. Still, would love a 2080 ti that could fit even if took a lil modding.
  • CPU is the one thing I'm unsure about at this point. The biggest downfall for me is not knowing what my limitations being a first time sffpc builder and having gone the route of the Dan A4
Otherwise, I figure more than likely a 645LT would be a wise choice for the upcoming build, assuming other hardware will allow it to fit.
I appreciate any help or feedback. Thanks!
