Advice USB C front port Dan A4.1
Shaytanya
38
Hi all - I have recently completed a Dan A 4.1 (high spec) build.
I receive the “USB device over current status detected” error if I try to plug in the front USB-C connector into the Mobo. If I do not plug this in, there is no error message - has anyone else experienced this problem / has a potential solution?
Thanks in advanced.
nightshift
177
105
Please share the motherboard your setup features. I suspect you have one of the b550-i's, either from Asus, AsRock or Msi as they are the ones that have front usb-c header without any adapter.
If you plug the cord into the correct slot, then it should work fine. Does it recognize whatever you plug into them despite the error message? Could try to update the bios too if you haven't done it already.
Shaytanya
38
Thanks for the response: I copy my set up list from a older post where I was showing off my mods. BIOS is up to date. It may well be that I totally forgot to check if that port is supported... I just get that message and am unable to use any functionality.
Part List
Main components:
  • Dan Cases A4-SFX V4.1 Mini-ITX Gaming Case Silver
  • Asetek 92MM 645LT Asetek extreme CPU liquid cooling
  • Noctua NF-A9x14 PWM Fan - 92mm
  • Asus ROG Strix Z490 I-Gaming
  • Intel i5-10600K CPU
  • Samsung 970 EVO Plus 250GB PCIe NVMe M.2 SSD – Primary drive
  • Sabrent 1TB NVMe PCIe M.2 SSD – Secondary Drive
  • Team Group 8Pack Edition 32GB (2x16GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit
  • Corsair SF Series 750W 80 Plus Platinum Modular SFX Power Supply
  • Noctua NF-A9x14 PWM Fan - 92mm (under MOBO)
  • Nvidia RTX3080 Founder’s Edition GPU
Custom/mods:
  • 2x Noctua NF-A4x20 fans – 5000RPM
  • For Raspberry Pi 4 Screen – 5-inch HDMI Screen Monitor – HDMI internal monitor
  • Cableec CYFPV Up angled 90 degrees HDMI ribbon cable (for the internal monitor)
  • Startech internal USB 2.0 Cable
  • 2x ASUS ROG Addressable RGB LED Strip 30cm
  • Pslate Customs – un-sleeved custom cables
  • Custom Side panel
