HDPLEX 400W AC-DC Brick Conversion Case Exist?
SoulTrain
21
SoulTrain
21
there's a modified SkyReach case on ebay, seller said HDPLEX 400W AC-DC fits perfectly.
Ya, I saw the video where Josh unboxes it and evaluates it. He was able to put it into a Skyreach, however he mentioned it wouldn't work with a bigger graphics card like a 1070/1080 or 2070/2080 Zotac mini.
CARC Mini
169
48
you're not listening.
he said that it won't fit exactly, in a standard SkyReach case.
but i'm telling you about a " modified " SkyReach, which is on ebay, where it will fit.
" modified " SkyReach case.
SoulTrain
21
Ah sorry, got ya. I wonder if Josh might provide an S5 again that is just a tad bigger. I like my S4 and would rather just have the AC converter in a brick however. ill look on ebay for that. thanks.
CARC Mini
169
48
there's no need for a bigger SkyReach, because it already fits his current SkyReach.
@Josh | NFC tells you this if you watch his other videos.
you do realize the difference stopping an exact fit, that he's talking about, is only 1mm, right ??
truth - 1mm.
SoulTrain
21
I saw how it fit on either side during Josh's video. Front and back it was too tall. The best place to put it looks like on the left side where the graphics card would go and that is the problem. If you have a larger card like a Zotac 1070 or 1080 there doesn't appear to be enough room. I believe Josh mentioned that in his video.
Josh mentioned that the largest graphics card that could go in with the AC-DC converter inside would be the Vega Nano. Josh does not recommend that card yet. Josh then goes on to say a 1060 would fit. He isn't sure about the new 20 series.
CARC Mini
169
48
by only 1 millimeter. i've done the math.
HDPLEX 400W AC-DC is 58mm, while SkyReach front is 57mm.
58- 57 = 1.
and as i've said, they're selling SkyReach cases on ebay, which are modified for that 1mm.
SoulTrain
21
Thanks Ill keep an eye on it. For those building new systems or wanting to upgrade your graphics cards here is a list and their dimensions...
ZOTAC GeForce® GTX 1060 Mini 174mm x 111.15mm
ZOTAC GeForce GTX 1070 Mini 210mm x 122mm
ZOTAC GeForce RTX 2070 Mini 211mm x 129mm x 41mm (8.3in x 5.08in x 1.61in)
MSi RTX 2070 Aero ITX 8G 174mm x 127mm x 42 mm
Penguin
40
58- 57 = 1.
You can probably thin out the metalcase on the Hdplex and if needed remove part of the bezel on the S4M, but that is a very invasive mod. In a month we will probably have a better view of the possibilities we have with the S4M and the 400W ac-dc togother, and what we need to mod for them to fit together.
Penguin
40
Josh talks about his plans to figure out how mill the AC-DC 400W a bit so it fits in the front of the mini here:
CARC Mini
169
48
yes.
as i've been telling @SoulTrain ,Josh said it wouldn't fit a standard SkyReach exactly, in the front.
he never said a modification of that 1mm would be difficult.
in fact, its pretty simple to modify for the front, since its only 1mm.
and they're selling " modded " SkyReach cases on ebay.
