Hi,
Just considering one of these for my Streacom DA2 case as it'll fit under the glass panel with clearance (145mm high)
Currently running a U9S in north/south orientation though, to go with the flow of the case (vertical airflow setup)
Can the H7 be mounted in north/south orientations? Any issues with the heatsink and ram colliding in such an orientation (running standard LP ram)?
I've searched a lot and can't seem to find much.
On performance it seems the U9S matches the Quad Lumi in a few benchmarks, but I figure they max out the fan speeds... in reality a Noctua NFA12x25 on the H7 running at lower rpm should be quieter and better performing I'd hope!?
Cheers for any advice!
