Hi,
I had a EK predator but I sold it before buying into the Ghost S1.... and now they have their new Phoenix AIO.
What I dont find any where is IF it is expandable so you can use your custom tube and fittings? There are no videos or anyone that has it to confirm this.
I am asking as it would be perfect for me as I am looking into cooling a 8700k and a FTW3 on a single 240 radiator.
Yes yes yes.... I know temps wont be super ideal but with the current tests that I am making then in a closed case with and OC of 5.0 at 1.34v and a slight OC on the gpu of +64 +350.
My temps are 69c on the CPU and around 53c on the GPU with heavy gaming. Fans on 900 rpm. Very silent.
I have been trying the BeQuiet AIO expanded to the GPU + 240rad + reservoir. The problem is that the pump is not very powerfull and to make matters worse then the only tubing I had on hand was the massive 19/13.
So the flow rate was very very poor. I will have to redo the tests with their standard tubing that is 12/8 i think or 12/10.
I have also been thinking of using the Alphacool Eisbear but I think it will be too tall for the Ghost S1.
Also I would like to a have a seperate pump and res as I would like to use the STRIX Z370I full cover waterblock.
