Hi guys i wanted to share my experience with the ghost s1 custom water loop. Since i only found one online and that had very little resources.
Here are some pictures of it:
its all made from of the shelve parts and a custom made water cooling holder bracket the original one had to much blockage. Im testing the noctua A12x25 the seem ok but only noctua can figure out a color that does not fit with black ?
the system currently runs a ryzen 3900x on 4.2 1,25 volts at 70 deg at bearable acoustics.
I have a custom made top grille coming in this week the first one i made didn't improve the thermals as desired (the standard top cover accounts for 4 deg worse thermals) I'm trying to come closer to the open thermals.
The system so far:
Gigabyte x570-I Aourus, ryzen 3900X, EVGA 2080 (non super), 32 GB balistix 3200 cl16, 2tb Corsair MP510,
and the water cooling part:
Alphacool DCLT 2600 pump with top, Alphacool 50mm tubular Expansion tank, Black ice nemesis GTS 240 (fits perfect in the ghost s1), XSPC Raystorm pro Cpu block, 12mm solid tubing, EK water push fittings, Noctua A25x15
The system so far:
