I had a thought last night about how to potentially get an additional 1.5mm of GPU clearance in the S4M in a brickless configuration.
While this may not sound like much in terms of additional space, it might be the difference between a GPU fitting and not.
The concept will involve removing and replacing the ends of the HDPLEX ACDC (pictured in blue) that will replace one of the panels (green) from the case.
This will then allow the HDPLEX to sit about 1.5mm further over, giving some additional room for GPU mounting (or even make fitting slightly easier).
Thoughts?
Thoughts?
