Brickless s4m with special VGA
M4rble
Hi there everybody
I just finish my brickless S4m with 9400f + 1650
The performance + temp is quite ok
But i want some GPUupgrade cuz i know 1650 dont need 400w hdplex
I found that i can put some bigger GPU that the power jack will fit inside the orange circle. So i dont need to remove top cover of hdp adapter, maybe just remove the 40mm fan of the adapter
Any idea for that???
S4
Reactions: CubanLegend
akisu
100
53
You can buy any card that has a width of around 110mm and use a adapter for the PSU connector https://www.aliexpress.com/wholesal...hText=Graphic+card+power+180&switch_new_app=y
