General Chat Thread
AleksandarK
/dev/null
May 14, 2017
703
774
While showing the A11 CPU, i can say that i was surprised with its performance. It is just so damn powerful.
Only if it could be scaled it perfectly to desktop...
5,986
4,974
If you don't need all the parts to be industry-standard, you can take a look at the Mac Pro 2013-Present to see what can be achieved with focus on efficiency, on the x86 platform.
EdZ
Virtual Realist
May 11, 2015
1,578
2,107
ARM cores really don't scale up well. Clock them up and efficiency ends up well below modern x86 (and x86 isn't too far off when scaled down) while not gaining close to the performance of a modern CPU in non-mobile benchmarks (all the "A11 faster than Desktop CPU X!" headlines stemmed from a single test in a single mobile benchmark, Gekbench). You can try and scale out by putting a whole pile of them on a die, but various companies have been trying that for many years and nobody actually want to buy them, mainly because there's not really any use case that isn't suited better by either a GPU (if you can scale out to a big pile of slow ARM cores, you can scale out even better to a vastly bigger pile of CUDA cores) or a Xeon-D (a whole bunch of cores, but the individual cores are faster and can run your existing x86 stack).
Soul_Est
1,536
1,928
Precisely this. The thing that makes x86 what it is are the longer and wider pipelines, multiple caches, and dedicated circuitry for various desktop and server workloads. Scaling up ARM can be done but you'll add complexity, size, heat which go against the markets that ARM and their licencors go for and can support. Perhaps if certain companies were interested in collaborating to create these large ARM chips, it could be done. Maybe.
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
I'm not saying I agree or disagree w/ anything being said here but there are some substantial efforts being made in the ARM server space.
Qualcom 48 core ARM CPU
Cavium Thunder X2
System 76 Starling Pro ARM
Not ARM and maybe the last of its kind but the Sparc M8 is just obscene. Also some other tidbits, Intel are pushing out new FPGA's, Nvidia are pushing new workstations w/ quad Tesla V1000's in, Intel also has new neural network processors. IMO outside of x86 things are actually getting really interesting.
My $0.02
Soul_Est
1,536
1,928
Cavium Thunder X2
My $0.02
Definitely. Always held a soft spot for DEC Alphas, SUN Microsystems UltraSPARC Niagara, and IBM POWER. I think that future CPUs will go 3D just like NAND did.
5,986
4,974
Power supplies are quite difficult to cool without a liquid medium between all the components. The only way I see this work effectively is if they seal the power supply, fill it with non-conductive fluid and attach a copper waterblock in there that can extract heat. That way it could also be completely silent. Now it's just an air-cooled PSU with a waterblock attached to some flat components.
VegetableStu
1,949
2,619
going down this rabbit hole a bit: I was about to say "why not heatpipe over the areas where the radiators are required and weave them through the PCB and solder/press onto the waterblock below?", then a bit more made me realise that other components need cooling of some form as well, especially kilowatt PSUs (thread related)
At this point it became an exercise of One Radiator-Canal To Cover/Cool Them All, so I stopped ._.
Also TIL Silentmaxx watercooled 500W PSU (still no pictures of inside)
AleksandarK
/dev/null
May 14, 2017
703
774
What is up with some Ryzen owners reporting higher specced CPUs than the model they bought for? Here's a Cinebench result showing 8 cores for a Ryzen 3 1200 with Ryzen 7-like results. Did they produce these from the same die, but disable some features like SMT?
Ryzen R models are made out of two CCX modules with 4 cores each. So they just disable some of the cores, or the CCX module hasn't passed the test with all 4 cores working and they for example use that one CCX with 3 cores and and they find another one like that, so it can create a 6 core ryzen 5.
From what i have read and heard, yields are 80%+, which means more than 80% of the CCXs actually has all 4 cores working, so a few chips labeled as R5, R3, can "slip". That is completely normal. It takes time to sort them all, and the demand is high.
Reactions: CC Ricers
VegetableStu
1,949
2,619
is there a thread limiter for xenforo?
(also is there recaptcha for xenforo?)
((also also is xenforo able to generate pages taking into account for ignored users?))
Reactions: AleksandarK
cmyk78
384
432
Firefox updated. Everything looks different. I am not OK. Send help.
EDIT: Quick google check, and I like everything except the new look.
5,986
4,974
10.000 Nm means a tectonic plate will shift if two of these do a drag race.
I wanted an EV sports car ever since the original Tesla Roadster, which still costs about € 60.000 (USED) here.
