News GEEEK N500 LITE specs revealed
GEEEK has just added the spec list to the N500 LITE. You can see them below or via the N500 product page.
Specifications
ModelN500 Lite
Available ColorMatte Black | Side panel : Smoked
MaterialsAcrylic, Aluminium Frame 1412
Case Dimensions166mm x 250mm x 289mm (W x H x D)
MotherboardMini-ITX (17x17cm)
Drives2.5″ SSD/HDD x2
Front portsUSB 3.0 x1
Expansion Slots2
Cooling SystemTop : 120x15mm Fan x1 (Optional)
Rear : 92mm Fan x1 (Optional)
Bottom : 120mm Fan x2 (Optional)
AIO Cooler92mm AIO x1
Power Supply TypeSFX / SFX-L
What’s in the box
  • 1 x N500 Lite DIY Case
  • 1 x Front USB 3.0
  • 1 x 16mm Power switch (Blue LED)
  • 4 x Foot pad
  • 1 x Screws
CPU CoolerMaximum Height : 135mm
GPUTaller than 265mm Length GPU
Maximum GPU Length : 280mm
Maximum GPU Height : 125mm
Maximum GPU Width : 40mm
Shorter than 265mm Length GPU
Maximum GPU Length : 265mm
Maximum GPU Height : 135mm
SFX-L PSU
Maximum GPU Length : 200mm
120x15mm Fan
Maximum GPU Width : 50mm
Without installing the 120mm Fan
Maximum GPU Width : 65mm
DrivesSupport 2.5″ SSD/HDD x2
Side drive maximum height: 9mm
FansTop : 120x15mm Fan x1
Rear : 92mm Fan x1
AIO CoolerRear : 92mm AIO x1
PSUSFX
SFX-L
Reactions: Jello and Phuncz
