GamersNexus: Would this be the correct orientation?
Arapaima
21
So I was cleaning my pc today and suddenly came across GamersNexus video on how to correctly mount an AIO. I know we do not have many options in our A4 case, but if we did, would this be the correct orientation?? And what about the pump it self? Since we are speaking of laws of physics, shoud the in- and out put of pump be oriented down insted of up?
Reactions: AseDen
AseDen
Asetek
Dec 7, 2018
194
295
www.asetek.com
I will just allow myself to quote a post I just made in another thread.
Sorry for being lazy and not realizing this post was here. My bad! Thought I had enabled email notifications ?
I'm one of his sources for information on why AIO orientation matters.
That being said, I think that there's a level of "drama" added to the content piece (and obviously the title) - but it's probably needed to drive clicks. That being said, there are of course merits to the claims made. Having the "wrong" orientation won't kill your AIO for any forseeable future unless it was constructed horribly and/or without sense of Quality & Control.
You are however likely to experience "gurgling" as I'm sure most SFF builders are aware of. It's not damaging (in any real or measurable way) unless you get to a point where evaporation through the tubes has allowed the pump to run completely dry (or maybe use a manufacturer that leaves 10% air in there - nearly choked on my coffee, there ?).
I would assume this mostly relates to the 645LT.
As I've mentioned on here a few times, it's fine to run it in its natural position in the Dan-Cases A4-SFX. Absolutely fine! You may experience the pump gurgling - because it's vertically above the radiator/hex. Now, there's a relatively easy (as if anything is easy in SFF, lol!) fix, which is flipping the rad 180 degrees, having tubes at the bottom of the case. This will allow air bubbles to stick in the rad/hex rather than the pump/block combo.
As always, happy to discuss further and/or get more in-depth :)
Reactions: dondan and tinyitx
