Hi all,
If I have 3.25 slot GPU (Sapphire Pure RX 9070 XT) would I be better off getting a T1 or Terra?
CPU (7800X3D) would be cooled by Thermalright AXP90-X47 Full Copper, either with Noctua NF-A9x14 HS or Thermalright TL9015W.
Mostly I'm trying to avoid turbulence, which I'm reasonably sure would be a problem in the T1 (since the configuration is basically maxed out). In the Terra I would use position 6 and have 5-6mm between the fans & panels.
Or would it be less of an issue since I can run the CPU fan slower and compensate with the top 120mm fans?
