you should have 60mm height available as 2-slot and 3-slot are 70mm and 50mm, respectively.If the 2.5 gpu slot parts attach to the formd t1 2.0, how much air cooler height will be possible? I hope to use noctua l12 ghost edition and 2.5 slot gpu at the formd t1![]()
Where do you find the black one? The common aliexpress stores only have the copper ones.In case anyone is interested in the Hanjiang 17mm radiator, I bought another two with black fins. Both of them leaked! I was able to fix them but they asked me to not talk about it. Of course I’m going to talk about it. They really need to do a 3-min leak test before they ship.
Would also like to know this! I just bought a copper finned one...would have gone black had I known!Where do you find the black one? The common aliexpress stores only have the copper ones.
Mine also leaked. They should add a fifth screw to seal it better:In case anyone is interested in the Hanjiang 17mm radiator, I bought another two with black fins. Both of them leaked! I was able to fix them but they asked me to not talk about it. Of course I’m going to talk about it. They really need to do a 3-min leak test before they ship.
Have you tried taking it apart? I was able to fix one of them by removing the end tank and cleaning up a small piece of debris that was caught between the o-ring and the housing. Hanjiang also suggested to me to sand the housing piece (the opposing surface of the o-rings).Mine also leaked. They should add a fifth screw to seal it better:
Can anyone recommend some alternatives that would fit this setup? Thanks!
If you're not planning on ever putting the GPU into the loop, I'd consider an AIO.I am looking to build a custom water cooling loop for my CPU in the FormD T1 v1.1. Like many, I was planning to copy the following setup from Ali at Optimum Tech:
Unfortunately, the pump and reservoir have been unavailable in the United States for several months.
- CPU Block: EK Quantum Velocity (cooling Ryzen 9 5900X)
- Radiator: EK CoolStream Classic SE 240
- Rad Fans: 2x Noctua NF-A12x15
- Pump: Alphacool DC-LT 2600
- Reservoir: Alphacool Eisstation 40 DC-LT
- GPU Block: N/A (air cooled 3080 FE, with T1 in two-slot mode and PSU offset with longer setoffs)
Same as the guy above said, if you have no intention to add gpu to the loop, just use an AIO, cheaper, and less hassel and not that mugh worse from a temp perspectiveI am looking to build a custom water cooling loop for my CPU in the FormD T1 v1.1. Like many, I was planning to copy the following setup from Ali at Optimum Tech:
Bumping so it’s not lost in the sauce, @Wahaha360, though I understand how busy you must be right now.I understand discontinuing the product to make way for v2, but how long out will the buffer be given, especially in light of the recent issues. Of course the worry being that a lot of us receiving our product in Q1 will likely have a few situations of our own that may end up needing minor parts, so I’m just curious as to when the full discontinuation will be to assure a sound product in the hands of those purchases in line.
For anyone wondering, I got the text from DHL a day before getting the shipping confirmation email. The sender of my case is listed as SHIFENG JUXING, which is... a tire company. The case is shipped from Singapore, although it could also very well be just on route.Mine was listed as"SZ JIANXIU ALIMIUM" by DHL. But that was back in october, so i don't know if thr recent shippments got the same.
Oh nice my cable tabs are slightly damaged as I tried to remove it. Haven't been able to find another with tabs, would be nice if it was sold separately like it is for the m1Hi girls and guy,
does anyone know what are the dimensions of those holes on the rear panel and which screw I need to fix regular ac power socket (bought a new one that come with socket you need to screw)
Thanks
