This is my new silent beast:
CASE: Jonsbo C2
MOTHERBOARD: Gigabyte GA-H270M-DS3H
CPU: Intel i7-7700
HEATSINK: NOFAN CR-95C
RAM: NR.4 CMK16GX4M1A2400C14 (64GB DDR4 2400Mhz)
SSD: CRUCIAL MX300 1TB M.2
HDPLEX 300W AC-DC + 400W DC-ATX
HDPLEX ATX PSU BRACKET
I had to open the top cover for fix the motherboard.
I fixed the two HDPLEX with some nylon screws/bolts.
I used a shorter AC plug instead of the HDPLEX.
The Heatsink touch the PSU bottom support of the chassis, so I put a rubber between them.
I know that for best venting I should use a top with holes, but this is what I have
This case is smaller than a Cooler Master Elite 110 but can fit some M-ATX motherboards!
I have only one problem with sleep mode, but everything is working perfectly on High Sierra.
CASE: Jonsbo C2
CPU: Intel i7-7700
