Prototype efficiency laboratories Communal Case 0.1 (CC-001) [LEGO]
el01
770
588
Front Range, CO
I will consolidate posts and cut out the crap from this thread for efficiency.
Thanks all for the feedback. (@Soul_Est-Was it you ;)) Development is starting on the PCC-02x family. It will be based on the PCC-01x family's frame with heavy modification and will support SFX units. Updates will be posted on my e-lab website or on SFF Forum later.
Reactions: Soul_Est
Soul_Est
1,537
1,928
That was me. While it would be cost prohibitive for me to prototype with real LEGO, I can beta test in a virtual space if you'd like.
el01
770
588
Front Range, CO
Thank you! :) Do you want the source files/ dimensions? I can provide those quite easily...
I can hypothetically do testing on my own if it's too much of a hassle for you.
The PCC-02.x series is going on pretty well. I have finished the frame and the following additions:
SSD mount, 3.5" mount, PCIe card support.
I will do a fan mounting system, a power button mounting system, and maybe a pump mount next. What would you like as a practical testbench feature?
