Dumb Question About T-Shirt as Filter?
Todayican2
42
Playing with an idea..
I'm a little concerned about dust with my 3 Liter design (It's a "lay down" GPU facing opposite the board, like the S4)
With both fans venting to "fresh air" I was thinking about sewing up a "sock" from either cotton or polyester t shirt material and slipping it over the whole thing.
This could solve a whole lot of esthetic problems as well (No need for fancy pants vent slots, just a wire-frame to keep the "sock" in the right form)
Anyone smarter than me ever tried this? I checked, polyesters flash point is about 120c and cotton is a touch higher..
EdZ
Virtual Realist
May 11, 2015
1,578
2,107
You could use material designed to filter out dust instead, e.g. HVAC filters, or speaker grill material.
Reactions: Todayican2
