PROTOTYPE: ON SALE (just case)
DOTDOC
Hi, im new to SSF so try to explain at my best. The idea was born while creating a new PC to get very small (possibly small) so i faced all the problems you allready know about. I'm 32 from Germany and a mechanical engineer.
So i tryed a lot an got to this :
Hardware
200$- ASUS Z270I ROG 17x17cm
350$- INTEL 7700k @ 4,9Ghz / aircooled
250$- SAMSUNG 500GB M2 PRO
130$- CORSAIR 600W SFX
150$- CORSAIR 16GB DDR4 3200
800$- ZOTAC 1080 Ti Mini / watercooled
100$- ARCTIC Accelero Hybrid III-120
10$- LEPA 120 FAN 2000U
30$- SCYTHE Big Shuriken 2 Rev.
20$- Raijintek Aelous Alpha 140 1400U
Case
and packed everything into 19x20x23 so 8,7L
Made by Jonsbo for me custom (150$) based on this:
reinforced with steel parts
Temps
CPU-Z + Furmark 15min:
GPU @ max 53°C
CPU @ max 72°C
PSU
HDPLEX 400W with 330W PSU wont work @ 100% beacause the peak load ist ~360W underwolting GPU and CPU it will fit.
DOTDOC vs ZOTAC
Ok now i know with lot of passion and shorting the wires and tubes i can get unter 7L but the "winner" is still ZOTAC with 5,6L
So let me show you some pics:
In a few days i will release a guide how to DOTDOC if you want you can donate or just have fun with it.
Future
In the funture i will re-ing. the cases and order 10x so if you want msg me.
I will also build a CPU+GPU watercooled peace.
Next flow up!
DOTDOC
Hardware
Case
Temps
GPU @ max 53°C
CPU @ max 72°C
PSU
DOTDOC vs ZOTAC
Future
Next flow up!
