I've seen many build in the first version (i think?) of the Sans, but I have yet to see a build in the MK2.
Does anyone own the Sans MK2?
How is the finishing of the case?
Did you use SFX or ATX power supply?
Does it look as nice as the rendered images on taobao, since I have yet to see a real image of them?
Did you get the Mesh, Glass or Aluminum side pannels or do you get all three from buying the case?
Is there any other direct way of getting this case without having to use Superbuy?
I am aware that the warhead maker is in this form, and I am wondering if I can buy directly from them rather than having to use Superbuy.
taobao link: https://item.taobao.com/item.htm?id=586712197113
