Does anyone have basic holes/measurements?
TwitchingDan
Building a dual mITX kinda cube-ish case ain't easy. Does anyone know common measurements, like PCIE screw threads and measurements? Mostly 120, 140, 200mm fans, HDD/SSD mounts, Board mounts etc.
TwitchingDan
4,783
200mm fans aren't really standardized so it'll depend on the particular model fan you're looking at more than anything.
4,783
It's hard to say without more detail. We talking 3 x 120mm fans mounts in the case vs 2 x 140mm fans? 360mm rad vs 280mm rad?
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
freilite.com
Well you need different mounting holes, but that's it. You should be able to design a mounting solution that fits either if you got the space.
If you have more specific questions about your case, it might make sense to open a thread about your specific topic. We're currently off-topic in respect to the original question.
4,783
Yep, fans or rads. Is there a mounting difference when designing? Not knowing sketchup makes sh*t hard!
Mountings are basically the same, if you have mounts for the fans the rads should mount as well. The tricky part with rads in they extend off either end for the reservoir tanks and fittings. So that's why many cases have slots instead of holes for the rad mounts in order for the rad to be shifted back or forth as needed to fit.
If you have room for 360mm rads then 280mm rads should fit too assuming the extra width isn't an issue.
TwitchingDan
So slots are the way to go?
4,783
If there's enough room in the case that the fittings on a rad would fit in either orientation, then it's not necessary. The slots are useful when there's limited space and the radiator will have to be shifted one way or the other to fit.
CC Ricers
2,234
2,557
Also since most radiators have their ports on one side (cross-flow radiators are not as common) slots let you orient the radiator in either direction depending on how you want to set up your cooling loop.
It also depends on how versatile you want your case to be for mounting options. Check the following video for the Evolv ITX case for an example:
At the 2:45 and 3:00 mark you can see the top panel with a *very* flexible set of mounting holes for various fan and rad configurations.
