hello everyone,
i have recently build the following setup:
Deskmini B250
Intel i7-7700k
GTX 1060
1 TB MP510 NVMe SSD
32GB RAM
Intel AX200 Wifi
My current modifications:
CPU delid
Jonsbo CPU Cooler with 25mm fan (instead of 15mm fan)
Liquid metal between GPU and cooler
RAM Cooler (22 x 65 x 6)
SSD Cooler (22 x 70 x 6)
Voltage converter cooler (60 x 100 x 10) on the bottom of the case instead of a hard disk. Therefor I added thermal pads beween the original cooler and the case
Asrock double USB mounted
One of the two universel single USB mounted at the back
LED 5050 strips sticked to the inside of the case
Current settings for the CPU:
-75mV Processor Voltage converter
75 Watt Power
85 Watt PeakPower for 1 secound
Setting for GPU:
-230mV at highest frequency
down to -100mV at lower frequeny
The setup is really super good. So much performance in a small space.
Unfortunately the GPU cooler is really loud under load. What could you do against it?
I hope you have good ideas and can help me.
cheers
DLone
Deskmini B250
Intel i7-7700k
GTX 1060
1 TB MP510 NVMe SSD
32GB RAM
Intel AX200 Wifi
CPU delid
75 Watt Power
Setting for GPU:
cheers
DLone
